4th gen fbody transmission cable
Oem cable is discontinued for my 1994 z28. This new cable has different ends. Ac delco 12558306. Where or what do I have to do to make this work. It's at transmission shop and seems like they are scratching there heads as well.
My junkyard replacement keeps coming of shift lever. I m not sure why. unless there is a different fix I plan on going with a new replacement cable GM 12558306 I'm not sure of the shift lever to make that cable work .
If you could be more specific you could get more accurate help.
Like what car?
What shifter?
What did the cable come out of?
Pictures would help.
Looks like Jegs has the cable new. https://www.jegs.com/i/ACDelco/065/1...BoCSlYQAvD_BwE
Trans lever you should have, found on google
https://ls1tech.com/forums/attachmen...m-ball-021.jpg
Trans lever you should NOT have https://i.ebayimg.com/images/g/CfoAA...MlI/s-l640.jpg
