? 6 speed auto to 4l60e c6 covette swap
Moderator
Besides the "bolt-up" issues, it should also be researched whether the C6 TCM supports the 4L65E. (oops, technical error, see my next post)
My C6 is manual.
My C6 is manual.
Moderator
Oops, the TCM for the 6l80E on the C6 is built into the transmission itself and communicates with the ECM and BCM via the CAN bus.
Therefore, to switch to a 4L65E will require determining which TCM is compatible with the ECM (and BCM??), mounting it and wiring it in.
First year c6 got the 4l65e stock. I would recommend sourcing parts from that vehicle as a direct bolt in option. Just as GM intended
Moderator
The 2005 TCM is available on ebay for $65; search "2005 Corvette C6 Automatic Transmission Control Module 24231673".
Anyone know if the 2006+ transaxle will bolt up to the 4L65E?
