Th400 vs Powerglide (Ws6 3550weight)
So Im looking into transmission options, I have 01 Ws6 ls1 forged, on nitrous but going twin turbo by end of the year hopefully, and Its gona be my race car, but I want it to be able to drive on the street, I wont travel more then 20-30miles with it. Currently has a 4l80 but tc are really expensive,trans brakes valve bodys are expensive and they say they work for 800hp with a shift kit but getting them at the junkyard, and rebuilding it because they got 200,000 miles on them, and still its a used trans with tons of miles on them, so Im better off getting a new one and saving weight, and getting it done without braking the bank is my goal.
So at what hp level would a powerglide be a better option?
What are pro and cons for each one?
My goal is to get into 9s eventually
Either a Powerglide or a THM400 would work in terms of power handling.
When both transmissions are built with the strongest parts made... The THM400 is the stronger unit with a far superior hydraulic design.
The THM400 has larger more robust parts that are near-copied for the turbine and output shafts on the highest power handling Powerglide transmissions.
However the Powerglide does offer less mass and consumes less HP. Which may be very beneficial.
The Powerglide struggles hydraulically with a trans-brake (aftermarket pumps greatly improve this problem), the unit was never hydraulically intended to operate more than one clutch pack at a time. Not enough volume of oil can be pumped fast enough.
Again however, both units live in vehicles with some where in the 2,000 - 3,500 HP levels...
The Powerglide units usually are "Refreshed" more often... Other than that...
You really have both options from a Power stand-point.
Most people that are making passes in the 9 second range are using a 3-speed, Not that you couldn't of course use a 2-speed. Obviously people do.
When continuing to go faster and faster; where more people may move to a 2-speed... Many people even convert the THM400 to a 2-speed
That topic is for another discussion and more money than is needed to spend for a 9 second vehicle.
I've seen glides run 9's at 4k lbs plus.
It's going to be a preference call.
Some will say you have to be th400 at your weight...but other racers with timeslips disagree.
The 400 *may* be faster...but without testing both and making sure both have the proper converter...there's no way to say for sure
The Powerglide struggles hydraulically with a trans-brake (aftermarket pumps greatly improve this problem), the unit was never hydraulically intended to operate more than one clutch pack at a time. Not enough volume of oil can be pumped fast enough. Stock pump glides at 1400 horse for seasons are going to have to disagree with you
When continuing to go faster and faster; where more people may move to a 2-speed... Many people even convert the THM400 to a 2-speed. Typically this is only done because you can't get a deep enough 1st gear with a glide. You physically run out of room for the gearset. But you can easily use 2nd gear in a 400 as an effective 1st gear.
My apologies most of my experience with Powerglide, THM400, and Turbo-Glide transmissions would be in the 2,000 to the blow-up a chassis dyno HP ranges.
Nice humblebrag. Stock pumps with stock size gears (assuming proper clearances) make 240psi all the time. That will knock out 2000hp no problem.
The only places I know doing anything different than stock (or SLIGHTLY over stock size gears just to get the clearance in spec) are doing billet pumps...namely the stator half, and that's so that they can run larger input shafts and have enough support for the stator to not rip the splines out.
regardless...If you read the initial post, you would see that this guy isn't trying to make 2000. He's closer to the 1400 or lower range...which you agree the stock pump is plenty capable of...so I'm not sure why your first post was to say that it struggles hydraulically?
C'mon, I am sure you know that when the Powerglide is near time for refreshment and clearances loosen up... Setting the trans-brake becomes more difficult and the vehicle can roll forward when on the brake.
Yes, glides get refreshed pretty regularly. It takes maybe 45 minutes to go through a glide if you're just slapping new frictions/seals in it on a weekend to get a racer to their next event. Take the time to measure and inspect everything properly for a season end refresh and you have more time in it, but it's still pretty minimal compared to most any other trans. I think its simplicity and low cost to refresh are common reasons people decide to refresh their glide as "seasonal maintenance" lol
But, for the OP...I don't think the hydraulic system is lacking.
Thanks for all the replies!! Im been looking into it and Im going with a th400, becuase I want to use it for street and be able to have fun with it even on low boost, and powerglide is more race only and on low power the gear ratio is far from being adequate.
bortous go home.
this is not the place for a 4l60e
it's 4l80e territory if he wants overdrive...but he has said he wants a th400 already so...
Thats what they always say about the 4l60s and they always end up braking down no matter what. And as well more expensive than just getting the right transmission to begin with. 4l60 is out of the question, I currently have a 4l80 installed, but I decided for the th400 because its less weight, and cheaper to repair, torque converter are alot cheaper and for a car that I want to be my track car it makes more sense. I just want to be able to drive it on the street but not travel with it though so I dont need overdrive .
A th400 he wants to get not a 4L80e. He already has it as stated by his post.
The 4L65E black edition is definitely worth a look.
We can all give an opinion.
I suggest taking your own advice.
Wondering why would you think a 5000dll 4l65 would be the best option vs a 4l80 or th400 that costs Less then 1/2 that price?
I know the th400 is cheaper and can handle more power.
However you have less gears.
That 4l65 box from performabuilt looks good.
I never said the 4l65e is better than 4l80e.
If you have the 4l80 just keep it and build it.
He already has a 4l80e. I know this.
Keep the 4l80e and rebuild it. Spend the money and get a converter to suit. No point getting the th400 and losing s gear and having no overdrive.
You have not tried the Black edition 4l65e.
I spoke to 3 people that have it that are running 1000rwhp for nearly 2 years and zero issues.
Technology changes so get with the times.
The one that doesn't understand my point is you my friend.
Originally Posted by Game ova
Those 3 people probably have more money than the U.S treasury department tied up in those 4l65s too. The simple fact that you would even fix your mouth to even form the sound 4l65, when in the company of a glide, and the almighty 400, automatically disqualify you from the discussion.
