Introducing ATK HP Stage 1 4L60E Transmissions
Debuting our new 4L60E, built to handle a modest 450HP. These transmissions will NOT come with a converter or TCM. They are built and tested in the USA! We have a few other transmissions in test vehicles that will handle up to 700HP and will be available soon! These are currently on special for $1499.00 out right, no core charge with FREE SHIPPING!
https://www.high-performance-engines...ons-s/2202.htm
- Heavy duty sunshell
- All new high energy clutches
- New high energy band
- New dual cage Borg Warner sprag
- All new durabond bushings, extra wide
- All new seals, gaskets and screens
- New 3/4 clutch piston, molded design
- New forward clutch piston, molded design
- New overrun clutch piston, molded design
- New Forward clutch accumulator, upgraded to aluminum
- New 1/2 Accumulator piston, upgraded to aluminum
- New Sonnax TCC regulator and isolator valve
- New valve body pressure control solenoid
- Updated pump with 13 vanes and Sonnax increased pressure boost valve 0.490"
- Fully assembly valve body function tested
- Fully assembled unit is dyno tested
