LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   1999 z28 doesn't shift into drive (https://ls1tech.com/forums/automatic-transmission/1924097-1999-z28-doesnt-shift-into-drive.html)
Deadeye5151 Aug 3, 2019 05:15 PM
Hi, new here. I recently purchased a z28 Camaro and it will not shift into drive or overdrive. I have just replaced all of the transmission solenoids and it still wont shift into drive. Is it possible the the bands have slipped? Any help is appreciated.
Tranzman Aug 3, 2019 08:40 PM
If you a getting a 1-2 shift and a slip with the 2-3 shift. The solenoids are functioning fine. Chances are you have the #1 Failure to the 4L60E transmission, 3-4 clutch. It's likely rebuild time. How's the fluid level? Is it Black?
Deadeye5151 Aug 4, 2019 08:44 AM
Thank you so much! I just looked into it and you are indeed right. It is the 3-4 clutch pack. Guess it is rebuild time lol. Again thank you for the help!
© 2026 MH Sub I, LLC dba Internet Brands
