LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   HELP Won't shift to 2nd unless off the gas (https://ls1tech.com/forums/automatic-transmission/1971973-help-wont-shift-2nd-unless-off-gas.html)
z28madness Jan 24, 2024 08:32 PM
My ol 2002 z28 camaro automatic, won't shift into 2nd unless off the gas , transmission fluid is good and still has color , when it does shift it shifts fine with no clunking. Is this early signs of the transmission going out? Or is there a bad sensor somewhere? Anyone else had similar problems? Any information helps. It's my only vehicle right now
FranksCustomTrans Jan 25, 2024 12:19 PM
Need more info like is the shift being commanded and then note happening or is it not being commanded, Where to start depends heavily on knowing this ,
mrvedit Jan 25, 2024 12:29 PM
There are no sensors involved. As Frank says, it is best to know if the shift is being commanded.
However, since a tune does not change by itself and from the age of the car, I suspect your band is starting to slip.
You can check this by pressing in on the servo cover with e.g. a crow bar and estimating how much it moved. 1/16-1/8" is good, 3/16" is marginal and 1/4" is where the band starts to slip.
Also check the fluid level which is best done with the engine running. (I find that with the engine off for a while, a fluid level 1" above the "Full" line is a good approximation of being full.)
© 2026 MH Sub I, LLC dba Internet Brands
