A4 cars with aftermarket trannies--inside please My car is a 2000 SS A4. I am getting ready to replace the 4l60 with a 4l80(manual vb--no electonics) My question is: What programming is required for the PCM? Do I just turn off all the codes? How does the car know when it is in gear vs when in park? Arent there different timing tables for the two? How are you wiring up neutral safety switch/reverse lights? What are the guys running T400/T350/700R/200R trannies doing to the PCMs to make it run correctly? Thanx Chad |
so no one has a T400/350 or other non stock tranny with the stock computer? |
I have an aftermarket 4L60 but use the stock PCM. I think a common solution is to flash the pcm to an M6, but I don't have first hand experience. 2 suggestions: 1) In this forum, review the last 2 weeks of posts or try a search; I know this topic comes up periodically. 2) Check in the PCM section. I think I have seen it discussed there too. |
© 2024 MH Sub I, LLC dba Internet Brands
