tranny temp gauge install
The orange/white wire to the stereo is the "illumination" wire, connect it to correct wire on the gauge per your instructions (you can also connect behind the stereo to red=+12v ignition and black=ground).
I just finished my trans temp gauge install today.
Bad30th
in JULY, i made 9 dyno pulls back to back followed by a couple quick blasts to check that the shift points werre correct and such and the needle barely touched on 180!
Vig 3200, 24K Cooler, Lowered coolin fan temp activation setting, BBK +3 quart finned, deep pan.
Bill
one time at the track a silinoid stuck and i made the 1320' in second gear only
. my trans temp got up around 200-205. Bill
Derek
Some people tap it into the pan, some put a "T" in one of the lines and mount the sensor there.
i did the sender hookup, all the wiring and mounting the gauge pod in about 2 hours.
What happens to the stock temp guage does the pcm not get a signal anymore?
