High Stall TC & Tranny Durability....
Old 11-27-2004, 09:52 PM
LS2 Pontiac GTO's Avatar
Default High Stall TC & Tranny Durability....
How would a 2800-3200 stall TC in my GTO affect the durability of the trans?
Old 11-27-2004, 10:13 PM
RedlineLS1's Avatar
It should be fine and hold up good. I have been using a 3800vig and have had no problems so far.
Old 11-27-2004, 11:01 PM
sleeperstyle's Avatar
cooler and shiftkit are reccomended. with those and tuning i would say the durability should be close to stock. just a verter and your asking for trouble- they create ALOT of heat. especially since you are not going to waste your $ on anything under a 3500 stall speed
Old 11-28-2004, 12:40 AM
How much more heat does a 2800-3000 stall TC create?
Old 11-28-2004, 04:31 PM
Moderator
jimmyblue's Avatar
I believe you would see (say) ~90% efficiency under
higher slips (the ~3000RPM are considered "mild" and
have reasonable peak efficiencies but when you slip
you are not too efficient.).
So call it a 10% loss. 10% of 300HP flywheel output
(just by way of example, no disrespect intended )
would be 30HP or about 20kW of heat to the fluid.
Mmmmm.... toasty.
Fortunately it's rare that you'd sustain that kind of
output for long, in a high slip regime. But you'd like to
be shed of that heat by the next episode, for sure.
Old 11-28-2004, 05:18 PM
1jfuddle's Avatar
A good trans cooler should do the trick, however I also run a deeper pan.
Old 11-28-2004, 10:10 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
I have over 115K on my Z28, with a 3500 stall since 4XK mile with no problems. I have a 25000 GVW B&M cooler that I run post-radiator in the summer and pre-radiator in the winter.
