Who built your 200R4.
LS1Tech Premium Sponsor
As mentioned, Century Automotive built our 200-4R. Mike at Century is the only transmission builder that touches our autos. We have really abused our 200, and it doesn't blink an eye. I ran it for a year in my '02 SS before putting it in our '98 Z28, and I ran a best of 10.13 @ 131 MPH on a 1.39 60' with it. I sent it back a year ago for freshening, and Mike said everything looked perfect. The 3-4 clutch pack was showing a little wear but nothing bad by any means, but I had him replace it anyways while it was there. We put the trans in our Z28 last May, and we've run a best of 10.20 with it with numerous 60' times in the high 1.3x range.
The 200-4R conversion is not cheap, but Century's transmissions are well worth it. Spend the money the first time to do it right, and you won't regret it. Feel free to give me a call or shoot me an e-mail at trevor@texas-speed.com, and I can put together a complete conversion package for you.
Trevor
Texas Speed & Performance
Trevor
sounds good i would just like to have a tranny that i dont have to rely on the computer to shift right and could put a trans break on sometime, It will be alittle while before i do this though,. I want to get a rearend and all the suspsion to handle the power before i put some power to my car. Just wanted to get some info on it. What all is required in the swap? reflash computer,converter, x-member i guess. what else? Does the 200 bolt right up or is there a special bell houseing used?
Thanks
Thanks
Originally Posted by slowbird21
Man that tranny already given you hell, hope you can get it fixed before you get your *** handed to you in the itty bitty ford lol
Thats it ***. Im scared of that POS mach 1.
You don't have to run Century's torque converter. I had TCI custom-build a converter for my 200-4R with no problem whatsoever. I can get you a custom-built TCI for the 200-4R with the LS1 pilot length and bolt pattern starting at $515. The price will vary some depending on stall speed, but it will certainly be cheaper than other custom-built converters.
Trevor
Trevor
CKPERFORMANCE out of New York is the best in the country with a 2004r
Check their website or Call Chris (owner)He also has a fantasic electronic transbrake available for the 2004r
Tell him Otto sent you
Last edited by Ragtop 99; 02-15-2005 at 11:29 AM. Reason: non-sponsor contact info
Trevor
Trevor
are they lock up converters?? Im gonna try to do this and a 12 bolt by next seseson. Thanks for the link KLHAMMETT. Ill deffintly look into them. I see they have replacment trannys for defferent cars does it matter which one its for.
Thanks for all the help guys
Ryan
Ryan
Ryan
He also builds a Hybrid AOD that they are using in 8 sec car reliably and still reatain OD
Check out these two sites they both do excelent work.
Bowtie overdrives
Performance Transmissions
I personally have you from Perforamance transmissions along with on of there restalled D5 converters in my 88 Monte SS. These two come highly recomened over on Turbobuick.com and MonteCarloSS.com.
Bowtie overdrives
