Removing the Torque Converter prccedure? FLP Trans is out of the car, going to pick it up tonight. I sold them separatly, how hard is it to remove the TC from the trans. |
btw - it is a 4l60e |
Not hard, just pull it off.. |
it pulls out. But on the install make sure that the input shaft engages all of the way onto the pump. If you don't then you will be pulling the trans back out. |
© 2024 MH Sub I, LLC dba Internet Brands
