Having my TCI SSF3500 installed tomorrow...
Old 04-04-2005, 06:50 PM
kpowr82's Avatar
Default Having my TCI SSF3500 installed tomorrow...
I'm getting my stall put in tomorrow by a reputable shop. Anything I need to let them know beforehand? NOBODY else has ever worked on my car aside from welding exhaust, and I'm kinda worried to leave it with someone, reputable or not.
Anyways, I'm very excited and just wondering if there is anything I should tell them before the install.
Thanks,
Matt
Old 04-04-2005, 07:38 PM
AK's WS6's Avatar
You should be fine. For any tranny shop a converter install should be cake. If they are installing the shift kit you might want to tell them how you would like the car to shift.
Let us know how you like the stall and shift kit. I just got my SS3800 today and I still need to order the shift kit, so i'd like to hear some input back from ya!! Oh yeah, are they installing a trans cooler also?? If not you should look into getting one.
Old 04-04-2005, 07:59 PM
Pontiacerator
RevGTO's Avatar
For the converter, as AK said, any shop that does a lot of tranny R&R would be good. For the shift kit, you definitely want somebody who is familiar with the Transgo kit. Shop around till you find one. When I called the guy who ended up doing mine, invited me to check out his shop. When I walked in, I saw a big stack of Transgo boxes in the corner ... evidence enough he knew what he was doing with these kits.
Old 04-05-2005, 09:29 AM
kpowr82's Avatar
Yup, I've got a TransGo and a B&M 24,000 going in at the same time. Damn, I'm sitting in class and I'm excited as hell to drop my car off!
Old 04-07-2005, 11:41 AM
kpowr82's Avatar
Car went in today.
Old 04-07-2005, 03:22 PM
02 wife's Avatar
Where did you have it installed?
Old 04-07-2005, 04:14 PM
2001NBMZ28's Avatar
Check your fluid level for the first couple days after you get it back just to be sure - mine was a little low and shifted funny until topped off.
Old 04-07-2005, 11:04 PM
franny40's Avatar
you are going to love that converter. the time i ran in my sig is also on 18" dr's.
Old 04-07-2005, 11:13 PM
kpowr82's Avatar
I've having the converter installed at Aggressive Performance on Groesbeck between 12 and 13 mile. Bruce seems like a really good guy, and his price was unbeatable.
I'll be sure to keep on eye on my tranny fluid. Thanks for the heads up.
I'm hoping to do a bit better than 12.5 with Headers and 3.23's. Traction may be a problem though. I'll try to get down to the track this summer and let you guys know.
I'll def. keep this thread updated as to my impressions on the converter. Picking the car up tomorrow morning.
Old 04-07-2005, 11:14 PM
kpowr82's Avatar
Just noticed you have a stall too. Where did you get yours put in?
Old 04-08-2005, 04:23 AM
TNormZ28's Avatar
If you have street tires forget about traction off the line. All three of those parts are very easy installs that any compitent shop should be able to fix you up with.
Old 04-08-2005, 12:07 PM
kpowr82's Avatar
Just picked up my car. I think I'm gonna break it in for about 100 miles before I get on it.
Couple question though:
1. What is this loud ticking I hear when I'm idling next to other cars. Sounds like a damn time bomb.
2. At very light load the 1-2 shift is crazy. It is VERY harsh. I haven't had any tuning done yet. Will that fix these problems?
Also, I died in reverse about 10 minutes ago. The general consensus is to raise the idle 100-150 rpms. Any other input?
Old 04-08-2005, 01:31 PM
kpowr82's Avatar
Here are my initial impressions:
WOW! I told myself I wouldn't get on it for the first 200 miles or so, but I couldn't help it. From about 55 mph I was trying to pass this truck. I gunned and held on for dear life. This sucker pulls now! The hard 1-2 shift apparantly only happens in D (3 for you Trans Am guys). In OD it doesn't do that.
The ticking noise is most likely an exhaust leak. I can already see where the y-pipe joins together that the clamp isn't very tight.
I still have a few things I want to test out, but they will have to wait.
1. 25 roll
2. Dead stop
3. 40-50 dead spot
4. 65 where the trans downshifts to the top of 2nd
I'll let you guys know.
Old 04-08-2005, 08:39 PM
Pontiacerator
RevGTO's Avatar
Did you install the Transgo? If so, how many spacers in the 1-2 accumulator? If not, your symptom is bizarre ... typically you can't feel the shifts after a TC install ...
Old 04-08-2005, 10:54 PM
02 wife's Avatar
Livernois Motorsports installed my Vig 2800. I also got a basic tune to adjust shift points. I had to have my idle raised also due to stalling. Its been in for three months.
Old 04-08-2005, 11:04 PM
kpowr82's Avatar
No, the Transgo hasn't gone in yet. It seems like it takes forever for the tranny to shift. It's kind of like when you're driving an M6. You push the clutch in, shift into 2nd and release the clutch. Now imagine it taking a full second to move the shifter from 1 to 2 before you release the clutch. It's like the car is hesitating to shift.
Old 04-08-2005, 11:16 PM
02 wife's Avatar
Its gonna take a lot of getting use to!
Old 04-08-2005, 11:21 PM
kpowr82's Avatar
You're having this shifting problem too 02 wife? Did you get a basic tune also? I called Livernois and I thought they were asking a little too much for the install.
Also, doesn't your converter feel really loose with those 2.73's?
Old 04-08-2005, 11:32 PM
02 wife's Avatar
I hated it at first! The shifts seemed slow and I did not like how the engine reved. I had a tune done to firm up the shifts. I have gotten use to the shifts and have adjusted to it. It seemed loose at first but I have been driving it, so its like normal.
Old 04-08-2005, 11:33 PM
Pontiacerator
RevGTO's Avatar
Well, I wouldn't call that a harsh shift necessarily - it doesn't sound like you're slamming the clutch pack with excessive force - more like a mis-shift. At this point I'm guessing ... either the trans is slipping because of an internal problem, or the PCM is having trouble figuring out what is going on with the new TC ... but then you'd probably be getting an SES light ...???
