LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   400 turbo, what's involved in the install. (https://ls1tech.com/forums/automatic-transmission/3032-400-turbo-whats-involved-install.html)
Black Sunshine/ 00SS Dec 8, 2001 11:48 AM
Thinking about it & wondering what all it takes to do the transfer.
Slow Z28 Dec 8, 2001 04:17 PM
Re: 400 turbo, what's involved in the install.
well, i'm thinking about doing this, but with the TH350. as for any adaptors or anything, i'm not really sure. but some stuff i do know would be a a trans crossmember, possibly new driveshaft and different yoke to go into the trans, and to get the computer reprogrammed to remove all the stuff that was needed for the 4L60E. you'll also need a shifter and a new shifter cable. you'll also need a new convertor to go along with that trans obviously. some people have stated that you can bolt up that trans right to the block, but won't uses all the bolt holes. the top one is not used, as well as the two bottom ones going into the oil pan. person i talked to said that those holes didn't matter and that there wouldnt be any oil leaks from not using the bottom holes. don't know about that one though. anybody else, cause i am interested in this swap.
Chris
AZZKICKER Dec 8, 2001 06:20 PM
HAHA I think I am going to set up a page with all of the periphorals and prices that guys need!
Its not to bad
I will list the extra stuff you will need:
New Drive shaft, with TH400 yoke
New Torque arm (unless you have someone that can weld you a new mount for your stock peice)
New Converter
Trans Tricker
Speed sensor and relucter wheel
Dip stick (Lockar Flexible unit)
New shifter (B&M Rachet or SCS Cheetah look nice)
Trans Brake (if you want)
I think I am forgetting something but I cant remember now.
The install it self is pretty straight forward. If you have a 12 bolt its takes allitle patience getting the torque arm to fit over the big rear.
Then just the asthetics of setting up the shifter.
and getting it the way you like.
I have a pic on my site of the finished shifter.
Good luck!
Slow Z28 Dec 8, 2001 06:26 PM
cool, there we go, a page set up with all the part #'s would be very helpful. cut down on the amount of posts about this hey? <img src="images/icons/smile.gif" border="0">
Chris
MacGyver Dec 8, 2001 08:54 PM
Tim (TimZ28), Richie (Richie Carbone), and myself will be completing my TH400/ 9" swap tomorrow. I was planning on doing a full write up on the whole ordeal. I'll prolly have it up monday sometime. Here's some misc pics of the process
https://hometown.aol.com/tofst4u2no/hammer1.jpg
https://hometown.aol.com/tofst4u2no/hammer2.jpg
https://hometown.aol.com/tofst4u2no/hammer4.jpg
https://hometown.aol.com/tofst4u2no/hammer5.jpg
https://hometown.aol.com/tofst4u2no/th400.jpg
https://hometown.aol.com/tofst4u2no/th4002.jpg
https://hometown.aol.com/tofst4u2no/rear1.jpg
https://hometown.aol.com/tofst4u2no/rear2.jpg
L8r
Will
B18B1LS1 Dec 19, 2001 06:47 PM
[QUOTE]Originally posted by MacGyver:
[QB]Tim (TimZ28), Richie (Richie Carbone), and myself will be completing my TH400/ 9" swap tomorrow. I was planning on doing a full write up on the whole ordeal. I'll prolly have it up monday sometime. Here's some misc pics of the process.
Just wondering if you ever did this write-up?
My 4l60E is toast and the TH400 is going in very soon. The more info I find on this conversion, the sooner I get to drive my car again. <img src="gr_grin.gif" border="0">
Thanks,
Jeff
98 SS A4
92 Civic 13.3 w/ bolt-ons
SCZ28 Dec 20, 2001 02:26 AM
There is a detailed swap here.
http://para.noid.org/~lj/
SCZ28 Dec 20, 2001 05:10 PM
[quote]Originally posted by WILWAXU:
<strong>
That's a kick ass website and car!!</strong><hr></blockquote>
He is very knowledgeable with LT1 Edit as well and just made a prototype "low impedance" kit for the OBD computer to allow the use of low impedance injectors <img src="gr_grin.gif" border="0">
WILWAXU Dec 21, 2001 12:01 AM
[quote]Originally posted by SCZ28:
<strong>There is a detailed swap here.
http://para.noid.org/~lj/</strong><hr></blockquote>
© 2026 MH Sub I, LLC dba Internet Brands
