Is a 3500+stall and 373s a good combo?
Old 04-24-2005, 09:07 PM
fivepointseven's Avatar
Default Is a 3500+stall and 373s a good combo?
Or should I stay with a lower gear? (I have 273s currently)
Old 04-24-2005, 09:56 PM
1jfuddle's Avatar
Lower gears(higher numerically) are a two sided issue.
First, they don't need as high of a stall to perform well with the same given setup.
Second, they make a higher stall feel tighter.
Basically, the big advantage to gears is that they let you get away with a bigger stall while maintaining streetability. It really depends on what you want out of your setup which way you should go. Lower gears will make the converter feel tighter around town. They will also make the converter stall slightly lower in most cases.
Oersonally, I say YES. They make a great combo.
Old 04-24-2005, 11:32 PM
franny40's Avatar
i have been in the same boat for a while i currently run a 3500 stall and i think i will be going with 3.42's but i have been told lately to go with 3.73's.
Old 04-25-2005, 07:12 AM
Moderator
JNorris's Avatar
I think it is a great combo. Go for it.
Old 04-25-2005, 07:36 AM
7 Second Club
ty_ty13's Avatar
i love my ss4000e with my 4.10s in a moser 12 bolt... drive it everyday... 30min drive one way
Old 04-25-2005, 05:01 PM
sleeperstyle's Avatar
your only problem will be hooking up. i like the highway gears and a big stall- KILLER on the street w/drag radials.
now, if you are going to go all out and throw some slicks on there, maybe even a rear, or go camm'd then definetly get the gears.
Old 04-25-2005, 11:26 PM
ULTIMATEORANGESS's Avatar
it makes your car alot more fun to drive.
Old 04-26-2005, 02:35 AM
TNormZ28's Avatar
Daily driven 4400 with 3.73's here. I'm considering 4.10's because I have some N/A rpms left at the end of the track and I haven't done a gear swap in awhile.
