SS3800 or SS3600 for a f14 cam which stall should i get with a f14 cam the ss3800 or ss3600 or go higher?. also wondering which gears to get with the stall 3.73 or the 4.10 thanks |
You need either the SS4000 or PT4000. The SS4000 will drive better but, the PT4000 will perform better at the track. Depends on how much of a track car you want. |
TCI 4400. 3.73's are more drivable on the street and will make the verter feel tighter. The 4.10s will just be crazy... But you should have enough rpms for the 4.10s in the 1320. I have the TCI 4400 with 3.73's and an FM 11 cam. I'm going to go bigger on the cam (non-Futral) and possiblly 4.10's depending on if I have RPMs left. Point is I really like the TCI4400 and 3.73 combo. |
You might run out of gear with the 4.10's if you have heads, run at sea level, or in cool weather. A SS4000 or YPT4000 and 3.90's would be a great setup. |
forgot to mention this is my daily driver also from time to time ill be running a 100 or 150 shot on this would this be a good converter to get? Pro Yank Extreme Converter PY4000E |
© 2024 MH Sub I, LLC dba Internet Brands
