Installed Vig 2800 and "check engine oil level" light came on.
Old 05-09-2005, 06:06 PM
FILE's Avatar
Default Installed Vig 2800 and "check engine oil level" light came on.
Right after getting of the lift, the light light came on. I am very connfused. How is this related to changing my stall. I have resetted my pcm and reflashed it and it wont go away. Please help..
Old 05-09-2005, 06:49 PM
firechicken2k's Avatar
might be a dumb question, but have you checked your oil level?
JaSSon's Avatar
Check the plug on the engine oil pan next to the tranny lines.
Old 05-09-2005, 06:50 PM
strokedls1's Avatar
Did you check the fluid level? The sensor is on the side of oil pan. Make sure it is plugged in and the wiring is ok.
Old 05-09-2005, 08:37 PM
FILE's Avatar
OK... guys.. I crawled under the truck only to find out they did not connect the oil level sensor back. I put back in and it was gone when I turned on my truck. Thanks..
