Stroker engines with A4, What are their trap speeds?
Old 05-31-2005, 11:54 PM
texada's Avatar
Default Stroker engines with A4, What are their trap speeds?
What kind of TRAP SPEED are you guys running with A4's ? Is a 3200 converter/3.73 gear the best combination for a street/strip set-up?
Old 06-01-2005, 12:11 AM
JZ'sTA's Avatar
I would go at least 3500+ on the converter.
Trap speeds should be 124 or better with a good stroker A4 combo.
Faster with a lighter car of course.
Old 06-01-2005, 08:59 AM
XTrooper's Avatar
I absolutely agree with this. Anything less than a 3500 will hobble your setup. This is especially true if you go with 3.73 gears. Also a 3500 will be fine with 3.73s on the street.
