Anyone Run 4.10's With Th400?? Do you drive on the street and what do you top out at?? |
I have a th350 and 4.10 in my daily driver. not really sure what it tops out at though. I have yet to go to a 1/4 mile track. but i'm guessing with my 26" slicks right around 120 mph. but it also depends on how high your revving it.6200 and 7200 are a big difference. |
we are running one in the LT1. TH400 and 4.10 gear in 12 bolt. its a bad idea unless you run a 28" tire or bigger and turn a LOT of rpms on the big end. |
see what RPM you shift and put that in to a tech calculator. But you are going to need to run a 28in tire anyway you look at it. |
So if I want to drive on the street 3.42's are better??? |
Originally Posted by NickcZ28 So if I want to drive on the street 3.42's are better??? |
Originally Posted by blkZ28spt 4.10's would be nuts in a street car. |
heck yeah... TH350, 4.30's, 28" tires |
go with some 3.90 |
ratios
Originally Posted by NickcZ28 Do you drive on the street and what do you top out at?? |
| All times are GMT -5. The time now is 07:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
