LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Here's one for ya (https://ls1tech.com/forums/automatic-transmission/342270-heres-one-ya.html)
Holeshotz Jun 25, 2005 04:36 PM
Here's one for ya
Last Night I was at the track and I went to launch and I heard a loud pop. The car stopped moving and I heard a clunking sound in my rearend so I limped it home and I changed my rearend. I then went to test drive it and the car still wouldn't move so I dropped it down to 1st and the car drove fine until I shifted into second and the rpms just went up but the car wasn't moving any faster. I then shifted to 3rd and the same thing happened. then I put it in drive and it engaged again but it won't go into overdrive. I have a 4L60E with a 3800 TCI, Trans go Shift kit, and B&M cooler. I check the fluid and it was at the proper level but it had a bit of a burnt smell to it. Any ideas what the problem is?
mrr23 Jun 25, 2005 05:31 PM
sounds like the reaction shell (sunshell) broke. one of the weak parts. basically, the trans comes out.
Holeshotz Jun 25, 2005 07:58 PM
How difficult is it to install a rebuid kit in a 4l60e? Does it require any speciality tools? I installed my torque converter and Trans go shift kit so I have some knowledge of the tranny.
menlatin Jun 26, 2005 03:31 AM
Well you need a new sunshell AND a rebuild. The sunshell is probably about as much as a FULL rebuild kit, so your looking at about $600 atleast to fix.
Holeshotz Jun 26, 2005 08:04 AM
Fromwhat I have read a broken sunshell means I have no reverse no 2nd and no 4th. I have reverse and no 3rd. So could it be something else.
© 2026 MH Sub I, LLC dba Internet Brands
