Tranny won't shift
Old Jul 10, 2005 | 08:36 PM
HAMRHEAD's Avatar
Default Tranny won't shift
Recently dropped the motor and tranny. Put a trans go shift kit in the tranny and bolted the new motor and tranny in and now when I go to put the car in gear, nothing! The shifter moves but the cable under the car doesn't move the linkage when I move the shifter. What could have happened?
Old Jul 11, 2005 | 07:55 AM
HAMRHEAD's Avatar
tt top
Old Jul 11, 2005 | 09:04 AM
James B.'s Avatar
The linkage is adjustable. The part of the linkage the cable attached to sildes inside of the part that attaches to the selector arm on the trans. A white piece of plastic with gear teeth locks into place held by a metal clip. If the clip of the tooted piece is missing it will just slide.
Old Jul 11, 2005 | 02:16 PM
HAMRHEAD's Avatar
found the problem. There is a plastic piece that is located were the cable assembly enters the interior of the vehicle that is broken. Will just have to order a shifter cable assembly.
