Having to manually shift my A4
Old Jul 25, 2005 | 03:24 PM
Formula94's Avatar
Default Having to manually shift my A4
When I leave it in Drive or 3rd it will not go from a stop, it acts just like the car is in neutral. The only way it will start moving is if I put the shifter to 2nd (it's a 94 so that is as low as it goes) and then manually shift it through the gears. Any ideas on what could be causing this?
BTW, I have a Pro-Built Automatics "limited" street 4L60E tranny, if that makes any difference.
Thanks,
Nick
Old Jul 25, 2005 | 07:20 PM
Rock-On's Avatar
Default hey
Sounds like a bad low roller clutch...Hope this helps Dave
Old Jul 27, 2005 | 02:49 PM
Formula94's Avatar
Thanks Dave.
Any other thoughts?
