ATF in a c5?
Old Sep 2, 2005 | 05:13 PM
speedyss's Avatar
Default ATF in a c5?
This is a stupid question but where do you check/add atf fluid in a 99 c5.
Old Sep 2, 2005 | 05:46 PM
john59's Avatar
Default Trans Oil
Hi,
The fill plug is on the left side of the tranny pan.With the car jacked on all fours and level, start the car put your foot on the brake and go through the gears put it back in park, go under the car and loosen the plug and take it out, you will need a pump that you can buy at any auto parts store to pump the new fluid in with and fill it till it starts to overflow out of the plug replace plug and tighten
Remember to leave it running
John
Old Sep 3, 2005 | 10:49 AM
speedyss's Avatar
thanks
