LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   slipping after putting on 315's (https://ls1tech.com/forums/automatic-transmission/391178-slipping-after-putting-315s.html)
badassls1z Oct 6, 2005 05:57 PM
i just got my tranny rebuilt about a month ago and added a Trans-go shift kit. i just put my new black ZR1 wheels with 315's on the back on last tuesday and installed my adjustable panhard rod last friday. well that friday night my tranny started slipping in 3rd and 4th gear all of a sudden. i stopped for a minute and checked the fluid and everything seemed alright, so i pulled back out and it didnt slip, then about a mile up the road it started slipping again. now it slips about half the time, you can take off from a light and it will slip then from the next light it wont. well today i put my stock 245's back on and now it dont slip. has anyone else experienced this? did the different size tires screw something up? what is wrong with my tranny? :confused:
thanks guys
cablebandit Oct 6, 2005 06:31 PM
did you change your tune for the tire size change? Maybe it is throwing the shift tables off and you got some lockup stuff overlapping shift points
badassls1z Oct 6, 2005 08:51 PM
no i didnt change the tune for the tire size, but i just went and drove it again with the stock size tires and it started slipping again, so idk what it is now, maybe the panhard rod throwing something out of line, im not very knowledgeable on automatic trannys, any suggestions?
thanks,
Kris
cablebandit Oct 6, 2005 09:02 PM
maybe the 3/4 clutches are about burnt up......
badassls1z Oct 6, 2005 09:13 PM
well damn............that sucks lol
thanks for the help man
Roarin_8 Oct 7, 2005 12:23 AM
I would say that something went awry with the transgo install. Panhard wouldn't have anything to do with the tranny. Either that or get a tranny tune, could be line pressure. Does your fluid smell burnt, brownish color?
badassls1z Oct 7, 2005 12:07 PM
yea when i checked the fluid right when it started slipping it kinda smelled burnt
© 2026 MH Sub I, LLC dba Internet Brands
