How do I shift my A4 based on RPM's?
Old Feb 14, 2002 | 10:31 AM
key master's Avatar
Default How do I shift my A4 based on RPM's?
Is there an automatic tricker out there? I think it would be nice to enable this at the track so I shift at a certain RPM each time, regardless of MPH.
Thanks!
-Jim
Old Feb 14, 2002 | 04:48 PM
The Guy in MY 99TA's Avatar
Default Re: How do I shift my A4 based on RPM's?
Well with the stock computer I had problems with that, so I had a shift kit installed with my last rebuild( my tranny has died 3 times) and it helped the 1-2 shift but the 2-3 shift was not improved and it hold into gear for a long period then shifts but 3-4 does pretty good too... 1-2 is very nice despite the point that I have a broken tranny mount and I refuse to buy anything from the assh*les at the local speed shop so I will have to deal with it for a little while or till I can get to another speed shop. You might want to see if you can have your pcm programmed, someone might can program it but I'm not sure
Josh Sullivan
