Passing gear doesn't work.. Normally would shift from 4th to 2nd at 60 mph but now will only go to 3rd.No loose wires and just had headers installed.Need educated.The performance shop messed with my Diablo a little. |
Originally Posted by hunterdawgs Normally would shift from 4th to 2nd at 60 mph but now will only go to 3rd.No loose wires and just had headers installed.Need educated.The performance shop messed with my Diablo a little. |
Thats unusual...I can't think of what would cause the trans to not go into second gear. The car goes into 2nd with no problem under normal acceleration? |
i had this problem before. a shift kit and and pcm would fix that. I would think pcm tuning would do it on its on though |
i had this problem before. a shift kit and and pcm would fix that. I would think pcm tuning would do it on its own though |
Boy I didn't see that you said the shop used the DS on your current program. If they modified your shift tables like jxaxsxoxn stated they might have changed the kickdown tables. If so it may not have even been intentional. I know when I first tried to mod my shift tables I messed everyting up on the downshit and had close to the same problem. |
| All times are GMT -5. The time now is 11:33 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
