LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Tranny won't shift out of 3rd gear (https://ls1tech.com/forums/automatic-transmission/419160-tranny-wont-shift-out-3rd-gear.html)
PERFECT Z28 Dec 6, 2005 02:31 PM
I had my VIG3200 installed about 3 weeks ago at the same time I had my tranny rebuilt. I haven't had a chance to go to the track to really see the launching difference because I just had my rear (10 bolt) rebuilt 2 weeks ago (3rd time :cry: ) and I just now finished ''breaking" it in.
The tranny seems to be working fine during normal driving (expect for the "3rd gear" vibration), but when I got on it the other day (WOT) it shift from 1-2 fine, 2-3 fine, but when it was time for the tranny to shift from 3 to 4...well, it didn't it just stayed at 6400 :bang: ...I let off the gas and it shifted 3-4. Any ideas on why this would be happening? :eek2:
Cheater Dec 6, 2005 02:39 PM
havr you had the car tuned
PERFECT Z28 Dec 6, 2005 02:43 PM
I had it tuned before the stall, but I think the shift points need to be adjusted?
PERFECT Z28 Dec 6, 2005 06:34 PM
Where should my shift points be at?
....VIG3200 with 373's rev lmt @ 6400
PERFECT Z28 Dec 6, 2005 09:25 PM
TTT...ne1?
PERFECT Z28 Dec 7, 2005 12:43 PM
...ttt
LS1FIRE Dec 8, 2005 02:10 AM
When you mean just stayed at 6400 in 3rd gear did you hit the rev limiter?
PERFECT Z28 Dec 8, 2005 12:59 PM
YES, it wouldn't shift 3-4 at WOT.
LS1FIRE Dec 8, 2005 03:24 PM
Maybe check you fluid level. Trannies are sensitive to that. My car would hit the limiter on the 2nd to third shifts allot before shiting into third. The fluid was a tad bit low added some it stoped. Hope you get everthing figured out. Take care.
PERFECT Z28 Dec 8, 2005 04:02 PM
Thanks
PERFECT Z28 Dec 9, 2005 02:01 PM
What should my shift points be at?
VIG3200 on 373's with 315 / 35 17's
cablebandit Dec 9, 2005 02:28 PM
i dont think stock tables will let you do a WOT shift from 3-4
PERFECT Z28 Dec 9, 2005 03:44 PM
Why not?
cablebandit Dec 10, 2005 05:48 AM
because 3-4 clutches are the weak link in a stock 4l60e. you can change that in your tune so it will shift
PERFECT Z28 Dec 13, 2005 08:34 PM
So, where about should my shift points be at?
GT Griller Dec 13, 2005 11:29 PM
Well u dont have a cam (looking in ur sig) so it would be a few RPM after peak horse power. I dont know why ur rapping it up all the way to 6400.
PERFECT Z28 Dec 16, 2005 02:20 PM
I'm going to the shop on Monday to finish my dynotune...I should be able to adjust my shift points as well.
therobman Apr 16, 2007 05:16 PM
i had the same problem it would redline my 2-3 and i also had a 3500 stall i got a crappy hypertech and fixed it all up
PERFECT Z28 Jun 1, 2007 11:04 PM
Dang, this was brought back...my shift points were off.
My tuner fixed it with HP TUNERS.
© 2026 MH Sub I, LLC dba Internet Brands
