98'Z28 LS1, hypertech -Shift points??
Old Jan 29, 2006 | 08:38 PM
hotrod44's Avatar
Default 98'Z28 LS1, hypertech -Shift points??
What the best shift points for 1 2 3 in the 1/4 mi. "0 - for 1"? "0-for 2"? who knows?
Old Jan 29, 2006 | 08:53 PM
Steve Bryant's Avatar
LS1 Tech Veteran
It depends on the cam, torque and HP versus RPM, rear axel ratio, etc. There are a number of variables.
Steve
Old Jan 29, 2006 | 09:58 PM
John_D.'s Avatar
This should probably be in PCM, or in Automatic Transmission.
Does hypertech use MPH or RPM? If it's RPM, then tie it to the torque curve. If it's MPH, you have to work backwards from your rear axle ratio.
Depends on where your rev limiter is going to be too. Don't want to be banging against that.
Old Sep 28, 2006 | 09:48 AM
Mike411001's Avatar
I know this is old but I'm also wondering where i should set my shift points. I have 3.42s and it uses mph
