4400 stall only brake stalls to 2200 Had my 4L60E rebuilt. Now it wont brake stall over 2200 and wont lock in 4th gear. It locks fine in 3rd though. |
brake stall and flash stall are different. lockup prob sounds like a tuning issue |
Was the convertor rebuilt as well? They can loosen up over time and the stall can get higher. If it's brake stalling a little less than it did before, that would be why. Or your brakes could be worn if you're always launching it that way. Edit: My flash stall is around 4200...for brake stall I would be lucky to get to 2500. |
my 4k only brake stalls to ~3k before it starts pushing the front tires. but it flashes slightly over 4k, it's hard to tell with the stock tach :| |
Cruise at a low speed and when you hit 3rd gear stomp it. And see where it hits at. Also try to flash it from a stop.. Stall speed can also be in factor to the weight and the amount of power the car has. |
© 2024 MH Sub I, LLC dba Internet Brands
