How much HP can a stock 4l60e handle?
I have an 02' Camaro ss A4 with bolt ons, but a stock tc + I'm spraying a 175 shot. For how long will my tc or tranny last?
I would say not much over 400. I don't think yours will last very long with that size shot. Change the fluid often, get a shift kit and pray a whole lot. You never know though.
Board Certified Idiot
Wet or Dry.?? get a tune if you are spraying that much. And is it from a DIG? all 3 play factoers in how long it will last and how often do you spray it. PPl in this site spray 150 with bolt ons on stock trans and still holding up fine.
guys how much can u spray on a wet kit with no tuning?i mean i plan on it using nitrous but i already rebuilt my tranny with rayabestos clutches and kelvar band along witha transgo kit.
i rember i had my wet kit from NX spraying 150. On my LT1 with only Minor Bolt ons and i did not need a TUNE and i was still good with out it.should have ran a fuel pump for safty but did not was still ok. This summer i will be putting the same kit and shot on my LS1. Few buddies i know do it now No problems
My trans started to bounce the limiter before shifting into 3rd with a cam, bolt ons, and a 150 dry. I would say the max a stock trans will take is around 425-450hp, and even then it might not last very long.
As you can see by the replys, you will want to use a "window" switch. This will always help, as to keeping the 2-4 band & 3-4 clutches alive. Without this, the realistic limit is about 450-475HP, there are always exceptions to this, but this is a good rule to follow from experience.
The vacuum modualtor should help some, especially the 2-3 shift at WOT. But more is needed than just the vacuum modulator. You will need to increase the volume of feed oil to 2nd & 3rd gear. This can only be done by modifying the valve body plate. I would add the larger boost valve from Trans-Go, as this will improve oil pressure & volume.
800-900rwhp,turbo for power adder,2900-3000lb car with 3:50-3:70 gear ratio,2800-3200 stall,street/strip car.
How long will the trans last,and what will have to be done to make it last.
Originally Posted by JAMES RODRIGUEZ
When I upped to boost and ended with 500+rwhp, the tranny died within a month.
the key to making it live betond the normal mods that are made is to take rotating speed out of the trans.this is only acccomplished by replacing the front planetary gearset with a custom one yielding a 2.66 first gear ratio.there only one place doing it and its us.i am currently signing up as a sponsor and will put links to the stuff as soon as the signing up is done so no one gets angry.if your unsure about my tech go back and read some of my posts
