opinions/facts transmissons
Old 03-03-2006, 02:46 AM
Collections Hold
Cary@Perf-Induction's Avatar
Default opinions/facts transmissons
Looking for a little insight. I am putting together a 99 T/A right now. It will be an everyday driver and will make around 625 flywheel hp. 402 ".
What have you guys had the best luck with for trans and converters. I was looking at the deal Yank has on their site with their trans partners.
I do not wand to sacrifice OD but I do not want to break either. Should I just work with the trans I have?? I want something that is just a bolt in replacement. It is mainly a everyday project car for testing our current and new products. I may spray the car real light, but no blower or turbo in the plans.
Thanks,
Cary
ET Performance
Old 03-03-2006, 07:29 AM
cablebandit's Avatar
with a little spray, you will be on the edge of a 4l60e. Have you considered a 4l80e swap?
Old 03-03-2006, 08:11 AM
Collections Hold
Default trans
I would, what does it take??
Old 03-03-2006, 08:34 AM
4l80/converter
crossmember
adapter harness
differet yoke for the driveshaft
you have to mod the tunnel just a little but its a 15 minute job.
Old 03-05-2006, 07:30 PM
Red Heartbeat's Avatar
Don't you need to have the PCM reprogrammed?
Old 03-05-2006, 08:12 PM
FLT
FLT's Avatar
Yes the pcm would have to be reprogramed. The 4l80 solenoids fire in a different order.
Old 03-05-2006, 08:24 PM
97F1R408's Avatar
Thanks,
Cary
ET Performance
Carey there are many upgrades to a 4l60-e that can be done to accomodate that kind of power. a 4l80-e conversion is stout but with the price and extreme additional weight you have to think about it. I have recently built a 2000 silverado with a 370ci 6.0 and I have fabed up my own turbo kit for it . It is at speed inc. getting tuned right now and I am expecting 650rwhp, I have used a yank 3600ss converter GM 5 pinion front and rear planets beast sunshell billet 4th servo corvette 2nd servo sleeved input shaft transgo hd2 2 5/8" wide 2-4 band special 3-4 pack all new bushings and borg warner plates as well as many other mods.You would also want to consider switching to vacum modulation If at all possible I would like to get something together for you. I am going to be purchacing a set of your 240's for my z06 from A and A Corvette maybe we can work together thanks Mason Smith
Last edited by Ragtop 99; 03-05-2006 at 09:05 PM. Reason: Non-sponsor contact & pricing info
Old 03-05-2006, 10:44 PM
Restricted User
CAT3's Avatar
Cary, dont even sweat the 4L60E. It may last, no offense there Mason, but not as daily driven, raced, dyno'd frequently R&D type car, thats just asking too much IMHO. I think you'd be wasting your money by putting anything into the 4L60E if the powerplant is more than stock. Either spend the extra $ for the 4L80E, or dump the OD and get with the old skool TH350/400. Sorry, been through a couple trans, and swapped out a few others for the same reasons, too much power = trans abuse.
Charlie
