700r4...
Old Mar 15, 2006 | 08:09 PM
thedudeZ's Avatar
Default 700r4...
Has anyone put a 700r4 into a '98+ F-body? I've done searches and not really turned up anything. My 4l60e is on borrowed time and I can snag up a 700r4 thats already built to take 600hp on the cheap. My only question is about getting the converter to lock up and getting my speedo to read besides hooking into the front right wheel sensor. I know I'll have to get a universal flexplate to fit the converter thats in the 700r4. I realize it is the same as my 4l60e almost but am not familiar with the differences.
Thanks for the help.
Old Mar 15, 2006 | 10:50 PM
2plus2's Avatar
can a 700r4 really take 600hp? the lock up can be put on a toggle switch
Old Mar 15, 2006 | 11:42 PM
thedudeZ's Avatar
700r4 has way more potential over a 4l60e so I'm told even though its almost the same thing. I'd prefer not to have to toggle switch my converter to lock up when I'm driving around.
Anyone?
Old Mar 16, 2006 | 01:09 AM
8a8mfh's Avatar
You need a spacer to fit the non LS1 converter. Spacer info.
You can wire one of the stock pressure switches on the valve body to lock the tcc automatically in fourth, just need to supply 12 volts to it. Or buy a kit from summit to do the same thing. Or buy a kit to lock it up hydraulically with a kit like This one.
For a speed sensor, get one out of a 700R4 with electric speedo. May have to reprogram the computer for the pulses per mile.
Old Mar 16, 2006 | 08:10 AM
thedudeZ's Avatar
Thank you greatly sir mucho appreciated!
Anything else I should know?
Old Mar 16, 2006 | 05:15 PM
8a8mfh's Avatar
Just make sure the throttle bellcrank geometry is correct for the 700R4 tv cable.
Good luck.
Old Mar 16, 2006 | 05:23 PM
thedudeZ's Avatar
Good luck.
We'll see how this goes, gonna start finding the things to make it work cause can only have my car down for 2 days tops(sat & sun).
Old Mar 16, 2006 | 11:00 PM
Strahley's Avatar
2 days tops is really pushing it, if either something goes wrong or you have to order a part!
Old Mar 17, 2006 | 04:54 PM
thedudeZ's Avatar
I think as long as I plan right and get the required parts I'll be fine. Only debate is if I'm going to go with a 3600-3800 stall or just drive the 2300-2500 it comes with. Thinking the later until more money comes and just drive the 2300-2500 stall with the new cam for a while. Not much point in a huge stall unless I have some DR's.
Old Nov 17, 2007 | 11:45 AM
946spdz's Avatar
700r4s suck i have a 500 horsepower monte and i put 600 dollars in the trany and it still blew up now i got a turbo 400 the best trany ever made
Old Nov 18, 2007 | 05:49 AM
LS1MCSS's Avatar
One problem you will run into is the throttle valve cable. It has to have the correct geometry at the throttle body connection or the tranny will never live very long. Bowtie Overdrives has a kit for this but it will only work with the small side plate on the throttle body. It will not bolt up on a 2000 and later throttle body. I have a 200-4R in my car but the throttle valve cable geometry is the same. I spent several hours building a mount setup that works. Depending on what year your car is, this may be something to check on before you start the install.
Old Nov 18, 2007 | 08:29 AM
8a8mfh's Avatar
Thats not much of a problem as it used to be. Might look into TCI's constant pressure valve body for the 700's. http://www.tciauto.com/Products/GM/gm_4L60E.asp
Old May 6, 2020 | 10:34 PM
CAM78's Avatar
I was wondering if you know of anyone who has used one of these and if so, what kind of luck did they have with it? Thanks
Old May 7, 2020 | 12:25 AM
sjsingle1's Avatar
holy 13 yr old thread revival batman ! does TCI even make that thing anymore ? the link is dead
Old May 7, 2020 | 12:57 AM
vorteciroc's Avatar
Probably not...
But both of GM's Throttle-Valve transmissions (THM200-4R and THM700-R4) can have their valve-body modified for full time/ constant line-pressure.
Old May 7, 2020 | 06:21 PM
sjsingle1's Avatar
so what is the purpose...benefit...of this mod?
Old May 7, 2020 | 06:23 PM
BBPanel's Avatar
Veteran: Marine Corps
https://www.summitracing.com/search/...n-valve-bodies
Old May 7, 2020 | 06:26 PM
BBPanel's Avatar
...But both of GM's Throttle-Valve transmissions (THM200-4R and THM700-R4) can have their valve-body modified for full time/ constant line-pressure.
How difficult is this to do? Price competitive to the TCI VB? I have an application that could benefit from the constant line pressure. -Bob
Old May 7, 2020 | 06:35 PM
sjsingle1's Avatar
so with this mod or VB you dont have to worry about improper TV valve adjustments?
Old May 7, 2020 | 07:48 PM
mrvedit's Avatar
Moderator
I am closing this 13 year old thread!
Please start a new thread if the content of it interests you; you can link to this thread if desired.
