Picking my FLT transmission will a Vigilante 3200 stall Fit a TCI Flexplate?
Old 04-22-2006, 09:14 PM
MetallicBluews6's Avatar
Exclamation Picking my FLT transmission will a Vigilante 3200 stall Fit a TCI Flexplate?
I have heard great things about Vigilante Converters and FLT transmissions. I know that Vigs are kind of Expensive compared to Fuddle, but I got a gift receipt from Speed Inc as a gift that will cover the cost of the Vigilante Converter.
Bottom line is that I have had a TCI Flexplate in my 2002 WS6 for over a year, because my stock on was flimsy and fell apart.
I plan on adding the Vig Coverter with the FLT transmission to the TCI flexplate. Do you guys know if the Converter will fit the TCI Flexplate??
Please HELP!! I am doing all of this on Monday of Next week
Robert
Old 04-22-2006, 09:27 PM
http://www.ls1speed.com/catagory.cfm...y=Transmission
Here is the link with the Vigilante Converter and TCI flexplate. Thanks
Old 04-23-2006, 07:41 AM
FLT
FLT's Avatar
The tci flex plate worked for your stock tc right? Then it will work with the vig. Call and talk to Chuck before you order your tc. I'm sure he can also help you pick out the right tc. So all you'll have to do is call speed and tell them what # you need.
Old 04-23-2006, 12:43 PM
Thanks Vince! I will call Chuck on Monday.
