Max RPM on 4L60E? 300RPM Change on shift point = hit limiter?
Thin is kinda a tuning and kinda a trans question but I'll ask here first. What is the MAX rpm on the 4L60e? My trans seems to get lazy the higher I spin my motor.
I used to have my shift points set at 6300rpm and my limiter at 6500rpm and ran time after time without a problem. After a recent dyno trip I realized that my HP was still climbing at 6300rpm so I changed my shift point to 6600rpm and my limiter to 6800rpm. At the track today, I hit the limiter on every shift, every pass. Same 200rpm split, no changes other than moving the limiter and shift point up a few hundred rpm. Why is it hitting the limiter now?
I pulled my shift points down to 6400rpm while at the track and my last pass I still hit the limiter. (Limiter was left at 6800) Also, the trans started shifting into 2nd before I got past the tree! It's never done this before and I don't know why it's starting it now, unless I really am just spinning THAT bad!
Any chance the trans is slipping up top?? At WOT you wouldn't even notice it that much as it would jump to the revlimiter before shifting.
Pontiacerator
This is from an Internal Engine thread ...
Originally Posted by Patrick G
RPM is one of the biggest killer for 4L60Es. You can put 600 rwhp to a stock 4L60E and if you shift it at 5500 rpm, it will last a long time. But a 350 rwhp motor shifted at 6800 will tear one up in a short time. Been there, done that. For maximum street miles, it's best to shift the 4L60E at or below 6000 rpm.
I guess that's the deal when you have an A4 and a cam the moves the powerband up. Either you fail to maximize the potential of your cam or you fail to maximize the potential life of your tranny. Pick your poison ...
Pontiacerator
Originally Posted by BlackHawk T/A
I remember that post, and I don't agree with it. HEAT and POWER are the main killers of the transmission. Have you ever seen someone break their transmission due to RPM? Didn't think so. How many have torched bands from heat or broken hard parts from stress?
A 350 rwhp motor shifted at 6800 will tear one up in a short time. Been there, done that. Joel and Predator-Z are saavy enthusiasts and know the pitfalls that come with a motor turning lots of rpm.
well, i have the same issues and i think the best thing to do is back down the shift points...
I have my rev limiter at 7200rpm and shift between 6400 or 6700rpm.
ji guess thats to much for the 4l60e?
I guess that's what i'll have to do then. I was shifting at 6300, reving to 6500 and everything was fine. Then I tried shifting at 6600, reving to 6800 and it will not shift. I backed the shift rpm down to 6400 but left the rev limiter at 6800 and it still won't shift.
The following users liked this post:
NewOrleansLT1 (11-19-2023)
Originally Posted by you2slo
Have you gone back to the original setting yet? Did that fix the problem?
