couple th400 q's I would need a 9" tail shaft to keep the stock driveshaft with the stocker rear right? What about when I upgrade to a dana 60? What is the pro's and cons of the 9" tail shaft, weaker, stronger? Are there any modifications I need to do to the bell housing for a th400? For a t-brake setup, what are you guys using to regulate your rev limiter for the tbrake? And as far as a converter goes, when I order one, I tell them it's going up to a flexplate for whatever year ls1 I have right? Will any ls1 flexplate work? Do I need anything special, shims/spacers? What do I do with my pilot bearing, since my car is currently a 6spd car? What wires do I mess with for the neutral safety switch? Any other speciality things I need to know? Thanks |
With a TH400 your going to need a custom driveshaft. The 9 inch tailshaft only works with a TH350 in a 4th gen. Not sure about a 3rd gen. Bell housing will bolt right up but you only use 5 bolts for an LS1.... I think. When I finally hook up my T brake I will regulate RPM with my foot :jest: You can use a 2 step for consistancy. Someone else will have to chime in with the LS1 flexplate question or you can do a search and get that info. I used a B&M SFI 153 tooth flexplate on my LT1. I just twisted my nuetral safety wires together and called it a day. Your going to need a way to mount your torque arm. |
| All times are GMT -5. The time now is 09:36 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
