Summer + AC = Crazy Underhood Temps... Normal ?
Old 06-01-2006, 11:22 AM
RahuL's Avatar
Question Summer + AC = Crazy Underhood Temps... Normal ?
Just wondering if it's considered *normal* for an A4 Cammed/Stalled Car to heat up to 220*+, in stop and go traffic with AC (NOT Max AC) on [ fan set at 2 ] .. with outside temperature around 80-82* and Humidity ~ 65%
When crusing above 45 mph, car temps hover around 200*. And, if completely stopped for more than 10 mins, the temp gauge starts rising to scary levels .. i/e past the HALF mark..
FYI:
1 - The coolant was flushed last year [using Dexcool ]
2 - Coolant levels are okay
3 - I have a 160* T-Stat and fan settings have been programmed into the PCM ; The fans do kick in as set up.
I'd like to hear from both Cammed/stalled ; Only Cam ; Only Stall ; Some Mods ; Stock guys.. So basically everyone chime is plz..
Also, please list:
1 - Your location
2 - Type of driving [stop n go ; highway ; traffic conditions if extreme .. ]
3 - AC ON or usually OFF
Old 06-01-2006, 11:56 AM
Moderator
jimmyblue's Avatar
I had this happen during summer in Georgia, hot
over-pavement air plus single-row radiator + A/C
heat dump = mmm, toasty. Wimpy little fans are no
help too. When the pavement is 150F and the air is
still, having a bottom-breather "cooling" air scheme
is not your best bet.
This was all stock motor & radiator. Been meaning to
get around to installing the LT1 rad for, oh, 6+ months
now....
I usually have the top down and the A/C off but had
to close it up and run the air; Georgia in July, nasty.
Old 06-01-2006, 12:08 PM
GregWS6&z28's Avatar
i've noticed mine are running a little higher also. I have manual fans, 160 stat, and still pretty much 195/195 engine/tranny temp when it's hot outside.
Old 06-01-2006, 05:02 PM
BlackHawk T/A's Avatar
Thats a perfect engine temp IMO...
