LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   hope it's not the transmission (https://ls1tech.com/forums/automatic-transmission/522563-hope-its-not-transmission.html)
ricardo colon Jun 9, 2006 04:02 PM
after 4th gear and it reaches 3500 TO 3800 RPM , the RPM starts to go down .WHY BAD SENSOR OR SOLENOID
sleeperstyle Jun 9, 2006 04:30 PM
you really have to give more details if you expect anybody to try and help you. maybe give us a schenario when it happens. the more details the better.
ricardo colon Jun 9, 2006 05:14 PM
it runs ok but after 4th gear and reaches 3500 - 3800 RPM it will not go any further , it's like loseing power and when i bring it back down to 3000 RPM it runs ok something like a safe mode , change optispark and TPS. :confused: just tested on N and it does the same thing.
ricardo colon Jun 10, 2006 02:27 PM
ANY BODY HOME :judge:
sleeperstyle Jun 10, 2006 05:15 PM
doesnt' seem like a trans issue- if it does it in N also...
FLT Jun 10, 2006 06:22 PM
Do you have cat's? If so they might be plugged.
ricardo colon Jun 10, 2006 06:41 PM
stock
FLT Jun 10, 2006 06:49 PM
Look into the exhaust being plugged or a drivability issue. This doesn't sound like a trans problem.
ricardo colon Jun 11, 2006 05:00 PM
driveability, like what
ricardo colon Jun 16, 2006 04:01 PM
took it to the shop and they said it's the transmission, what solenoid would cause this problem. :bang:
ricardo colon Jun 19, 2006 05:27 PM
anything would help
ricardo colon Jun 22, 2006 10:54 AM
i think i'm going to sell the car and see if anybodyis that crazy to buy it
© 2026 MH Sub I, LLC dba Internet Brands
