Do I need an install kit for gears if I'm not doing it?
Old May 13, 2002 | 04:48 PM
quickWS6's Avatar
Default Do I need an install kit for gears if I'm not doing it?
Do I need any type of install kit if I am having a shop install the gears? A new cover gasket will come with the TA girdle I am getting. Thanks a lot.
Old May 13, 2002 | 07:13 PM
Brother J's Avatar
Default Re: Do I need an install kit for gears if I'm not doing it?
I think you will end up saving money by getting the install kit yourself, rather than having the shop charge you list prices for the bearings/seals/crush sleeve/etc. You probably can save even more by bringing your own diff fluid. BTW, to take full advantage of the extra rigidity of the TA cover, you won't be using the gasket. Use Suzuki 3-bond (or was it Yama-bond) gasket sealer.
