going from 2:73 to 3:73...worth it?
$500+ is around a quarter of the 12-bolt's price. yea, they're expensive, but it's better than snapping your rear and just being out $500+. My STOCK 10 bolt broke at 60,000 miles with a STOCK motor. STOCK tranny, STOCK geaers. No exhaust. No lid. Not even a damn K&N air filter.
I have seen MANY cars on this forum run 11s with the stock 10 bolt with 4.10s, 3.73s, 3.43s, 3.23s and 2.73s.
I have seen many cars on this forum go to the 10s on a sick H/C setup, a nice cam N20 setup, and FI setups and the factory 10 bolt.
Why in the world would you buy a new rearend before it breaks? A new rear is around $2000 done right. Then you have the install.
You are recommending a $2000 difference in price when it is NOT needed (yet). $500 is not that much to spend at one time on gears. Get the TA cover, some Moser axles and have a strong rear end for 1/2 the price of a 12 bolt.
Some people (like you) are not going to go all out with their cars and will not require a 10 bolt. It is unwise and uneducated to say that running gears will ruin your rearend. All cars are different.
Hey Choco, I knew a guy who died in a car wreck. I wouldn't drive ever again if I were you, because it COULD happen to you. Same ******* logic. It COULD happen, not DEFINATELY, but it could. So why in the world would you give advice telling someone not to run gears in the stock 10 bolt when SOOOOO many people have with great success. Sure, some people don't have good luck with them, but many do.
Jesus choco, I give up....you're right. While we're at it, what do you recommend for my next mod? I see now how you've accumulated so many posts in 6 months.
You really need to stick to things that you have experience with and quit basing everything you tell people off stuff you read. People are telling you the exact same thing in an external engine thread right now. Listen for God's sake!!! Last edited by jmm98LS1; Jul 14, 2006 at 04:24 PM.
Here's the way I see it. Unless you ordered your 4K stall with a high str for the 2.73s (I would guess close to a 3.0 for a DR/ET street car), then that stall may not work great with the 2.73s and you may need to look at a gear change after the TC is installed. Also, while a gear change may not net you alot of time, 2.73s to 3.73s will make the car a whole different animal on the street.
Bottom line is, if your looking for a fun street car, get yourself some gears. If your a budget drag racer and your stall works well with the 2.73s, keep them. Also keep in mind that if the car is hitting hard out of the hole with your 4K/2.73 combo, then switching to 3.73s is only going to create more traction issues and you'll have to start looking at the suspension and tire combo. Just my opinion of course.
a rear is made of more than one part...wow, didn't know that. i've always assumed a differential, gears and axels were all the exact same word...hmm...
that being said, i don't think he's posted in 8 pages. i guess he made up his mind. i'm surprised this hasn't been locked a week ago.
Unless you don't have it tuned correctly
