LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   A4 Q's (https://ls1tech.com/forums/automatic-transmission/539483-a4-qs.html)
LetMeBurnU Jul 10, 2006 08:27 PM
A4 Q's
Does all 98-02 camaro/firebird come with 2 D option? [D] and D. Which is good for daily driving both street and freeway? I usually just drive with the D just above the 2&1 and the car seems to be louder and the car really slows down when I take my foot off the gas pedal, mostly on the freeway. Is that normal..?
BlackHawk T/A Jul 10, 2006 08:32 PM
On the Chevy it's 1-2-D-OD
On the Pontiac it's 1-2-3-D
The reason you are experiencing that is because you are in 3rd gear and not 4th (overdrive). You are running a higher RPM. Use overdrive for the highway and freeway.
8a8mfh Jul 10, 2006 08:44 PM
The reason it slows down more in D than in OD is because in D the over run clutches are in use, they provide engine braking.
LetMeBurnU Jul 10, 2006 09:55 PM
Will it hurt my transmission when I use D instead of [D] on the freeway...? Which one is better for Gas mileage??
2002_Z28_Six_Speed Jul 11, 2006 03:56 AM
That doesn't make any sense because the 1/2 support roller clutch is overrunning in 3rd AND 4th gear. Are you talking about a 4L60E? Maybe you are familar with a different type of transmission.
I thought it was more of a gear ratio thing slowing the car down.
8a8mfh Jul 11, 2006 05:57 AM
Yes I'm talking about a 4L60E, when you shift it to third the over run clutch comes on and it provides engine braking.
BlackHawk T/A Jul 11, 2006 08:41 AM
It's probably a combination of the two.
© 2026 MH Sub I, LLC dba Internet Brands
