LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Why doesn't anyone.... (https://ls1tech.com/forums/automatic-transmission/546688-why-doesnt-anyone.html)
Frosty Jul 23, 2006 07:18 PM
restall the stock converter? I read on here all the time that people are having lockup issues on their 9.5'' converter. The clutch goes, I guess because it's so small?
Why not just restall the stocker?
BlackHawk T/A Jul 23, 2006 07:32 PM
Because its big, heavy, and a drag on performance.
kruthes1 Jul 23, 2006 09:55 PM
Yeah what he said
CAT3 Jul 23, 2006 11:09 PM
A lot of the Lockup issues are from not having the PCM tuned on when to lock it and unlock it. You can burn a TCC up in a matter of a couple miles if its not right.
sleeperstyle Jul 24, 2006 08:29 AM
so how does it have to be tuned?
12secSS Jul 24, 2006 08:44 AM
The stock converter will not be able to stall past 2500 and be efficient for street use, that is why. As CAT3 mentioned, the stock lock up table are intended for a tight converter. On a loose converter (some of) you will experience lock up issues. So it is best to readjust both the shift tables and the lock up tables, as well as the line pressures.
© 2026 MH Sub I, LLC dba Internet Brands
