Trans won't shift after big tire spin?? OK if I get on the car hard with street tires on it and the RPMs go up FAST due to tire spin, the trans will not shift. Some times it wont shift out of 2nd at all, some times I have to shift it manually, and other time it would not go in to OD. Now if I shut the car off and back on it will shift good again. WTF It is a stock trans with a Yank SS-4000 stall and a tune I don't race it that much at all, the car has 40000 miles on it and it may see the track once every 3-4 months. What is the problem??? Is the trans going , I riley don't think so because some times it works great. And I do have a BIG trans cooler. |
Do you mean the trans won't shift while your burning up the tires, or the trans won't shift after you have burnt up the tires? |
Won't shift after until I shut it off and restart it. |
May be sliding into "abuse" mode. There is something like a minute or two timeout for that though, after which it should release (get normal)? Maybe some other fault that self-clears and needs two in a row to set the light. Maybe you should do two or three (one per key-on) and see what pops up. With a high stall speed there are some slip / performance codes that may set and prevent lockup or modify shifting but I don't remember them other than 1870. |
| All times are GMT -5. The time now is 08:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
