LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   a4 ws6 99 won't crack second somethin wrong???? (https://ls1tech.com/forums/automatic-transmission/583701-a4-ws6-99-wont-crack-second-somethin-wrong.html)
logsws6 Sep 28, 2006 04:17 PM
cars stock but i had a 87 formula 350 that would
02NBMFormula Sep 28, 2006 07:25 PM
crack second??? you mean chirp the tires going into second??? if so torque management pulls timing on shifts so theres a nice drop in power(thank you GM) if you want to chirp second, get a tuner to delete drivthe torque managment and that should help. check to see what gears you have in the rear(check the drivers side door jam, GU5 is the RPO code for 3.23's the highest from the factory for auto's, if it is GU3, i believe you have 2.73's then and its harder to chirp second.) if all else fails, get a high stall, tranny cooler and a shift kit. if your on street tires, youll be spinning nicely on the upshifts
BlackHawk T/A Sep 28, 2006 08:19 PM
And ripping up your tranny, sounds like fun.
02NBMFormula Sep 28, 2006 10:10 PM
what?
logsws6 Sep 29, 2006 05:11 PM
crack chirp all the same slp tuner would work ????
thanks for the info
todddchi Sep 29, 2006 05:57 PM
A shift kit is the cheapest and "safest" method here. The mild setting will be enough to get a nice chirp, but this change may be more aggressive than you'd like. Hard enough to get chirps at less than WOT, this is the cheapest and most reliable way. But, it is harder on your rear diff and to some extent the trans. The general understanding is a shift kit is worse on hard parts (breaking) and better for soft parts (slippage).
A tuner will also work but less reliably. Trannys have variation and some may not be able to be tuned with a handheld to make them chirp. There are many concerns with the changes the tuner making not being the best for the tranny.
You can study up to make your own decision or take the recommended route with a shift kit.
logsws6 Sep 29, 2006 06:34 PM
thats what i want .....chrip 2nd without WOT....but like i said it dosen't do it at all...i'm gonna have to read up on it the harder the better
thanks for the advice
todddchi Sep 29, 2006 07:31 PM
Try searching under line pressure and shift kit. You should get the hits you need.
© 2026 MH Sub I, LLC dba Internet Brands
