What size converter for a 228R on a 112LSA
Cam is texas speed 228/228 .588/.588 on a 112LSA, which size converter will work best with this application? 3000 stall?
If you are looking at some track mostly street you could look at getting a 3600 or a 3800 stall. 3000 is a little small IMO but some will disagree. Your cam doesn't really isn't gonna play a big part in what stall you need. It will more depend on what you plan on using the car for.
street only, and it may see the track once a year 1/8th mile. how bout a TCI streetfighter? its 1500+ rpm increase in stall over stock. dont know what the str is and does the str matter?
Originally Posted by Z'mnypit
What gears? I ran the TCI SSF3500 with the 2.5sr with 3.73's and it wasnt loose at all. I loved that converter.
