V6 4L60E case and bellhousing same as LS1? is the case and bellhousing of a 4L60E trans from a 99 V6 bolt up to a LS1?? thanks... |
Well the bell will bolt up but the input shaft and pump are quite different , Using that trans would require at the least swapping the input drum and pump stator.And the units may be otherwise weaker in several ways |
© 2024 MH Sub I, LLC dba Internet Brands
