4l60e to a 4l80e. i need some info plz!!! well my 4l60e is on its way out i think. and im thinkin bout goin to a 4l80e. but im not sure of a few things. 1- will the computer be the same and how bout the wiring harness hook ups? 2- will my 4l60e crossmember work with it? 3- i think the drive shaft will be the same but not sure? 4- what is the best year to put in a 95TA? 5- will me 4l60e converter work? 6- and if i have forgot anything plz put it out there thanks guys |
t t t |
Originally Posted by SexyTransAm well my 4l60e is on its way out i think. and im thinkin bout goin to a 4l80e. but im not sure of a few things. 1- will the computer be the same and how bout the wiring harness hook ups? 2- will my 4l60e crossmember work with it? 3- i think the drive shaft will be the same but not sure? 4- what is the best year to put in a 95TA? 5- will me 4l60e converter work? 6- and if i have forgot anything plz put it out there thanks guys 1 - no, the PCM controls each differently, and the harnesses are different (80E requires 2 VSS's vs the 60E's 1, and the round green connector is configured differently) 2 - no, the trannies are different lengths 3 - no, the trannies are different lengths. You might be able to change the yoke, I know the 2wd truck guys can change yokes and be fine. The output shafts on the 60E vs 80E have different spline counts and the 80E is larger IIRC. 4 - not sure 5 - no |
ok i was going to do the same swap on my ls1 car but decided to sell the car. I order the harness adapter from speartech.com also you are going to need a converter and a flex plate . and the dimemsions of the tranny are different 4l80e is longer so you need to make a crossmember or modify it and a shorter shaft. |
well hell it sounds like im goin to stay with the 4l60e. all that is too much work for a car with just a few mods |
I just ordered a 4l80-e tranny that comes with everything I need. These are the parts it comes with: # Wire Harness # Crank Spacer & Bolts # Crossmember # Custom Driveline Yoke # Dip Stick Tub # Transmission Mount # Connection Lines & Fittings # Transmission # Torque Converter Shield The yoke allows you to use your current driveshaft. I also had to get another torque converter. |
© 2024 MH Sub I, LLC dba Internet Brands
