LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Automatic Transmission (https://ls1tech.com/forums/automatic-transmission-13/)
-   -   Need a Quick anwser from you A4 tranny guru's (https://ls1tech.com/forums/automatic-transmission/7411-need-quick-anwser-you-a4-tranny-gurus.html)
U-Luze Nov 4, 2002 08:57 PM
I just my car back togther finally, And im have the tranny woes again. My converter was Just rebuilt by Yank the other day so im pretty conifidient thats fine. I have a Vacuum modulated transmission, The Tranny guy at the dealer just built the trans on the side with Level 10 parts and every thing checked out fine. He give me a pressure gauge to hook up on the pressure port on the drivers side just above the gear selector. It read no pressure at all. Could this be the Pump or the Modulator not letting it get any pressure? He said the pump checked out fine, Also would the modulater have any effect on the line pressure at idle? Like its just dumping the fluid back in the pan not pumping anywhere? Thanks Justin
U-Luze Nov 6, 2002 07:21 PM
Re: Need a Quick anwser from you A4 tranny guru's
ttt
© 2026 MH Sub I, LLC dba Internet Brands
