Tranny Line Connections...
Well my Z28 didn't come with lines at all so not 100% sure on how they route to the radiator.
I have found a post on here and one on another forum that say 2 different things.
I have a 4l60e transmission as well.
There is a top and bottom connection on the transmission then the lines run to the radiator. Now I know where they go on the radiator as they only fit in 1 spot but where do they go on the transmission? Does the top spot on the tranny go to the top spot on the radiator and so on?
Reason I ask is I have a set of tranny lines and they just do not seem to want to to fit when I try to run them top to top and bottom to bottom.
Thanks,
Mike
Thanks,
Mike
I am not sure I have every pais close attention to that detail.
But, knowing that the lower port on the trans case is out to the cooler and the top is in from the cooler.... and a radiator flow is the top hose in from the engine, and the bottom hose is out to the engine... I would say that the lines are going to go on just like they want to and you'll be just fine.
g
g
