Anyone Use The J.w. Ultra Bell?
Old 09-19-2007, 06:09 PM
MOSTDELUXE's Avatar
Default Anyone Use The J.w. Ultra Bell?
Just wondering how they fit and how bad they are to install any issues?
Old 09-19-2007, 06:32 PM
Loadre's Avatar
Got one on my TH350 and just put the trans in. I have just as much room as the stock bellhousing in my opinion.
Old 09-19-2007, 06:34 PM
FLT
FLT's Avatar
I have heard on the ls1 engines there is a slight clearance issue with the block. I can remember what it was but I was told that there was a little grinding that had to be done to make it work. Vince
Old 09-19-2007, 06:45 PM
MOSTDELUXE's Avatar
I think the bolts on the rear cover hit the inside of the ultra bell
Old 09-19-2007, 07:40 PM
98turbls1's Avatar
This is true... I just did mine on Monday and all that you have to do is put the bellhousing up to the back of the block and tap it a little to get the indention (pretty much grime on the back of the block =) ... After that just take a drill and clearance those holes (3)... Put it back on and try again to see if you got exactly where it need to go... I really like mine and there's pretty good clearance... I have a 9.5" converter and there's plenty of room in there... I just wouldn't go with a stock size converter because there's not THAT much room..
Old 09-19-2007, 07:47 PM
FLT
FLT's Avatar
I do not believe that a stock size converter will even work with a JW bell. Then again if your using a JW bell you probably have no use for a stock converter. Vince
