OD in my 4l80e doesn't work correctly... My '92 K2500 4x4 has a 4l80e trans. My OD is not functioning right or left (ha). OD engages upto about 65 mph but then it downshifts to 3rd. I have changed alot things, close to rebuilding the dang thing. I changed the solenoids because when it shifted, it slammed in each gear. Here is a small list of the things that I have changed: converter solenoid (three sets, last one from GM) pressure reg od solenoid cleaned the valve body ECM TPS :bang: I recently scanned the trans and I saw that the speed that the trans was showing was about 20 more than the speedo was registering. Is this correct? I asked a couple of mechanic friends but they did not know alot about electronic trans. After reading alot different forums and websites, I have found out that the computer may think that it is towing something and that maybe the reason for the downshift. Is there a method of calibrating the little box that reads the speed sensor (VSS)? :confused: If there are any other suggestions, I would like to hear them. Thanks for any help in advance. |
If the PCM does not see lockup it may disable fourth have you had a scanner on it to actually see whats its doing ? |
PM`d you performabuilt. |
I did scan it a few days ago but the only thing I remember is the mph difference. i will need to go back to my friend and get the specs from the file I saved on the scanner. Is there any specs I need to watch for? |
| All times are GMT -5. The time now is 04:16 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
