How soon must I tune? Installing a Fuddle 3600...
Converter is going in on Monday... First chance I get (within the month) I have a cam going in.
I don't want to pay for a tune twice so how driveable/not driveable is it going to be with this stall installed without a tune?
I have a 1998 Z28 with a full intake and exhaust, stock 3.23's and the converter is a Fuddle 3600 2.2 STR.
If I just drive it normal (not WOT runs) I am assuming I won't have to worry about the rev limiter and throwing the codes, am I correct?
LS1Tech Sponsor
PWM is pulsed width modulation or regulated converter clutch slip. Not the best idea in my opinion but really bad with a small diameter converter. The problem is the amount of slip is controlled by regulating the presure to the lockup clutch, The amout of slip is based on the stock converter clutch size so lets say the smll converter has 30 percent less area on the clutch then there will be 30 percent more slip that was intended, Eliminating it changes the lockup to a simple on off operation and keeps the clutch applied when enabled at max presure for little or no slip. But you cae as I mentioned in another post sounds more like and engine missfire issue if its after a longer drive.
__________________
well it happened after dropping off a kid to his house and when we went to get back on the HWY it would not shift to OD this trip was about 50 minutes long so I guess after 25-30 minutes of driving is when it happened? should I check the fluid? I am about to finally get a tune on it tomorrow but now I wonder if it's too late? is the tranny in trouble?
To the orginal poster, you can wait on a tune untill you are ready. I've put almost 10,000mi on my combo with no tune, mainly because there are no really pressing issues that i'm too concerned about.
O/P... you should be just fine for a while. If you are concerned, get it done soon. If not, drive it ... enjoy it!
Omega... Did this happen today as well? Or at least in a subsequent drive cycle. I would wonder too if it was simply not locking up but was indeed achieving OD. Meaning, if it did not have OD at highway speeds, when you came to a stop it would be in 3rd when you accelerated from that stop. Did you see any warning lamps?
g
g
g
g
Well... sorry for the .... maybe we should start a new thread entirely.
To begin with you need to identify the exact condition. Define what is taking place and why. It may be a huge waste of time to chase engine misfire when indeed that is not the case.
Get a scanner on it, drive it, duplicate the symptoms and see what is happening. From there make your determination for proceeding further.
Feel free to give me a call tomorrow... I'll be in all day and can walk you through whatever you find. Or better yet, drive out here and I'll take a look at it myself and we'll see just what is happening!
Good Luck.
g
Good Luck.
g
